Newbie
Cruzer Blade 4GB - driver not found in Windows 7 upon first installation
Can't work this one out.. my 4GB Cruzer Blade fails to install properly the first time around. Windows 7 (both x64, x86) sits there for about 10 seconds before it says driver installation failed. If I unplug and replug the flash drive, it detects it properly and installs the driver. From this point onwards, it's fine.
This happens on about 4 computers, all Intel based, all admittedly running windows 7. Strangely, windows XP works right off the bat. 4 other various brand flash drives are seemingly detected properly first time around, so on one hand it looks like Windows 7 at fault, on the other, it looks like the flash drive.
Has anyone else experienced this?
Newbie
Re: Cruzer Blade 4GB - driver not found in Windows 7 upon first installation
Also finding extreme annoyance factor with this. SanDisk 4GB. Cruzer Blade. Windows 7.
SanDisk Guru
[ Edited ]
Have you written to the manufacturer of Windows 7, ie MICROSOFT, and ask them why THEIR product is doing that?
Of course there is also the possibility a security app is getting in the way.
Ed
Newbie
Newbie
Newbie
Cruzer Blade 4GB - pendrive not ditect
Sir
     my  sandisk cruzer 4GB pendrive is now not working.i purchased pendrive from Reliance Mart Tirupati.on 3/April/2011.when i approach to reliance mart they are telling that only company is giving  warranty.from their information and sending this mail.please do the needful. I expect some reply from you
Thanking You
prathish james
SanDisk Guru
Re: Cruzer Blade 4GB - pendrive not ditect
prathishjames2 wrote:
Sir
This is a user's forum. If you are looking for an official response from SanDisk you should direct your inquiry to one of the Support contact numbers here:
http://www.sandisk.com/sandisk-support/contact-us
Newbie
I purchase befour six month Cruzer Blade 4GB pan drive but now getting problem to formating  Cruzer Blade 4GB  please send me the driver and how to install
Newbie
