Newbie
Can not download torrents directly on usb otg (dual drive)
I can copy/paste files to and from the usb but can not download torrents directly on the usb as it says write protected. Is there any way I can remove this protection?
SanDisk Guru
Re: Can not download torrents directly on usb otg (dual drive)
[ Edited ]
If you can copy & paste files to the drive it obviously isn't a drive problem.  Sounds more like a Windows or security app limitation.  Or maybe whatever app you are using to download your torrents.
Ed
