Newbie
8gb cruzer blade has become 64 mb skybird
I have brought an 8Gb cruzer blade 2 month ago . but now When I put it in the computer it shows as Sandisk firebird 64Mb unformatted. When I try to format it gives an error reading. I have tried using partition master and it also cannot format this drive or show the correct drive size.
Using diskpart in windows also doesnt work.
even does not work
i tried to format it in macos fail
used command promt also failed
How do I get this 8Gb drive formatted?
please help me soon so that i can use it
SanDisk Guru
Re: 8gb cruzer blade has become 64 mb skybird
that is a bad drive most likely contact sandisk support. 866-sandisk
Newbie
I had the same problem, but i installed ubuntu (dualboot between windows 7 and ubuntu), then looked around tills i found a hardware manager(i dont remember what that thingy was called), and i clicked on a label with my usb name, then i formatted it from there... and then when i booted windows, the usb had no problem.. it was like.. new.
//Max
SanDisk Guru
Rather than installing UBUNTU onto the hdd download the Desktop Edition and write it to a USB or CD and boot it from there.
Ed
