Newbie
Accepted Solution
128gb sandisk ultra usb 3.0 flashdrive
I've formatted the drive to exfat. I've then moved data on it to almost full capacity and it worked fine all day. Next day, it's saying the format is unrecognizable and it's showing as if there's nothing on the drive. I always unplug after selecting remove usb but somehow it's showing up as raw. Is there a way to retrieve the files back? Is this a faulty stick that needs replacement?
SanDisk Guru
Re: 128gb sandisk ultra usb 3.0 flashdrive
Try running CHKDSK on the drive and see what it reports.
Ed
Newbie
I did. It said can't run on raw format.
Newbie
Ok, now that I've given up and formatted, when I plug it into a PC it gives me two drive letters... Or gives me the name I've formatted it in with the full size, the other just named "usb drive".. Apparently the one I named can be used but the "usb drive" needs to be formatted. What is going on here?
SanDisk Guru
It sounds like you either bought an old U3 drive, which SanDisk stopped making about 10 yrs ago, or you bought a used flash drive that someone partitioned.
A seller problem.  Return it.
Ed
Newbie
Any other suggestions? This is a brand new Sandisk ULTRA 128gb usb 3.0 flash drive...
Sounds like Sandisk isn't paying attention to quality control anymore... Bought both new. One fine, one it sounds like you're saying is defective. 50% fail rato is terrible... Ran disk surface test. 70% off the sectors are corrupt... Never getting sandisk again. People should stay away.
SanDisk Guru
This is not a new SanDisk flashdrive.  It is a counterfeit.  Return it to the seller.
Ed
Newbie
HIGHLY doubtful. You're telling me best buy themselves would be selling counterfeit sandisk ultra 128gb usb drives??
Newbie
Most certainly a new sandisk drive. Quality control issue
Newbie
The other place I purchased from? Amazon. Directly from them, not third party for either.
