Administrator
SanDisk Extreme SSD Firmware R211m download for for MacBook and MacBook Pros based on NVidia MCP79 chipset
[ Edited ]
Disclaimer: This firmware will configure the SSD drive to operate at SATA II/3.0Gbps and will no longer function at SATA III/6.0Gbps. The fix is only recommended for MacBook and MacBook Pros dated in 2008-2009 based on NVidia MCP79 chipset. To reverse the SATA 3Gb lock please see the r211R firmware download links below. This will set the SSD back to default FW.
WARNING: Applying the wrong firmware ISO to your SSD product will render the drive unusable! Please confirm the capacity of your SSD product before proceeding with the firmware download and update.
Step 1:
Verify the capacity of your SanDisk Extreme SSD and download the corresponding firmware ISO
SanDisk Extreme 60GB SSD
60GB R211m Firmware ISO
SanDisk Extreme 120GB SSD
120GB R211m Firmware ISO
SanDisk Extreme 240GB SSD
240GB R211m Firmware ISO
SanDisk Extreme 480GB SSD
480GB R211m Firmware ISO
Step 2:
Burn the saved image file to a CD/DVD with another software application then boot from the CD and perform the firmware update.
a.    Restart your computer.
b     With the firmware disk inserted Press and hold the “C” key while the computer restarts.
c.     After restart, your system will boot to the SanDisk Firmware Updater
d.    Select the drive you want to update from the list displayed.
e.     Press ENTER to start the update.
f.     When the update is completed, Press ENTER to shutdown computer.
g.    Remove the boot CD/DVD from the drive and restart computer.
h.    That’s it…finished!
The following Firmware downloads are used to reverse the 3Gb Lock.
Step 1:
60GB R211R Firmware ISO
120GB R211R Firmware ISO
240GB R211R Firmware ISO
480GB R211R Firmware ISO
Step 2:
Newbie
Re: SanDisk Extreme SSD Firmware R211m download for for MacBook and MacBook Pros based on NVidia MCP
Shouldn't we get a .dmg file? My optical drive is dead and I'm trying to restore the image to a USB key so I can boot from there but no checksum is available to verify the file.
Thx!
SanDisk Guru
no you will need the ISO to create a bootable disk and boot into the fimrware updater. this drive does not support live update (updating from within the OS)
Newbie
That's not what I was asking. I do have a USB key with the ISO installed on it, done on my PC with PowerISO but this seems not to work on the MAC. Another solution was to restore the image to the USB key using DiskUtility on the mac but the image needs to be verified to proceed which it cannot do because of no checksum available.
Newbie
Is it possible to install this firmware to a SSD by using a non-Mac computer, or must the update process itself be done on a Mac?
Using the SSD Toolkit I made a bootable USB on a PC with this firmware for the 120GB SSD. After rebooting from the USB, the firmware update software started the update process, but immediately stated "The update process failed."
(Fortunately it did not brick the SSD in the process).
The same procedure with the "regular" (non-Mac) firmware suceeded.
SanDisk Guru
try burning a CD instead of using a bootable USB. please note that while the firmware can be updated on any machine you should only use it on a computer that has an Nvidia MCP79 SATA chipset.
Newbie
My MBP optical drive is dead. No surprise here. So I can I pull the SSD and put it on my PC and do the upgrade there?
SanDisk Guru
yes you can
Newbie
Thanks, this worked!
I'm trying to use this 211m firmware on an Asus laptop (K50-ID) with Nvidia MCP79/7A chipset. When using the standard firmware (201 or 211) the SSD is not recognized by Windows installer at all, and system logs when booting from Ubuntu Linux CD indicate many errors.
With 211m I can see the drive in both Windows installer and when booting from Ubuntu Linux CD, and I can create and format partitions. However, Windows refuses to install to any of the partitions with the following error:
"Windows cannot be installed to this disk. This computer's hardware may not support booting to this disk. Ensure the disk's controller is enabled in the computer's BIOS menu."
Does anyone know how to fix this?
Newbie
Should I use the R211m or R211 firmware for my MacBook Pro, 13-inch, Mid 2010 with chipset NVidia MCP89 AHCI?
