Newbie
Accepted Solution
ReadyCache + ExpressCache not work
I have a Win 7 64 bit SO
My SSD SanDisk ReadyCache 32Gb is not found by ExpressCache
Why!
SanDisk Guru
Re: ReadyCache + ExpressCache not work
the i100 is not a readycache ssd. The software you are using is the retail version and only works with the ReadyCashe SSD part number SDSSDRC-032G-G26 which is a 2.5' SATA SSD.
Newbie
Tnx.
What kind of softweare should I use then?
I would to use this ssd disk for accelerate my HardDisk
SanDisk Guru
Software should be available from the computer manufacturers website.
Newbie
If you do NOT activate ExpressCachewithin this time frame, caching will.
