Newbie
Accepted Solution
Difference between SSD and UltraPlus
After digging around on internet and getting no results can someone please outline the differences between the standard SSD model and the UltraPlus. They are both priced almost the same locally but I can't figure out which is better/newer. Which controller is used on the SSD? Think the UltraPlus is Marvell?
Thanks,
Andy
SanDisk Guru
Re: Difference between SSD and UltraPlus
Ultra plus SSD uses a marvell controller whereas the sandisk ssd uses an internally designed SSD controller. The ultra plus has far better IOPS performance. See the spec sheets below
Ultra Plus
http://kb.sandisk.com/app/answers/detail/a_id/12504
SanDisk SSD
http://kb.sandisk.com/app/answers/detail/a_id/10864
Newbie
So given that they're priced the same the UltraPlus is the best choice. Any benefits to choosing the SSD?
SanDisk Guru
if price is about the same i would go for the ultra plus.
