I’d like to play the Sansa Fuze through my home stereo. What would be the best way to set this up? Thanks!
Did you read the previous posts in this thread?
If you’re looking for the Sansa Base Station, it is no longer listed in the SanDisk store (or on Amazon), but you might be able to locate on elsewhere.
Otherwise, you’ll have to get a jumper cable (with male plugs on both ends) and use the headphone jack out to the AUX IN jack on your stereo. While not the best option, it will work.
You get a cord that has a stereo minijack–like the thing on the end of your headphone cord–at one end, and whatever connector your stereo will accept in its Aux jack.
The terminolgy (jumper cable) may not be the correct description, and you may have to use an adaptor plug on the stereo end but yes, this will work. You won’t have the advantage of the remote control the Sansa Base Station has, it won’t charge and the sound quality and/or volume level may be not as good as using the dock’s line out connection but you’ll have music.
