Login Problem
I followed the forum advice to open the flash drive and delete files. Now it says the disk is empty and there is no longer a secure login. Now I cannot access the  files I put on the flash drive. So what do I do now???
Ive got a sand disk eye-fi 4gb wi-fi and I have for got my password can tell how I can get thanks you
hello mr Ed. if i got the same problem. i forgot my password. my question is if i delete all files in the drive, are the files inside the vault going to be just fine or lost? thank you
Lost.
I did as you suggested and deleted the files.  and now I have a new PW.  How do I view my files I had stored in the vault prior to loosing my PW?
You can’t gardnert.  They are gone.
Has worked so far deleted all on cruzer, now to retrieve. Here’s to trying. Thank you, scuderoo2010
